John Deere Model G, s/n 55272
jon
08-11-2004 14:52:46
Need info, is this a "gas" or "diesel" model. The specs state that this tractor runs on "Dist." as opposed to gas or diesel ??!? It does have two sparkplugs screwed into the head however they might be utilized ffor preheating the cylinders as opposed to providing spark. NEED INFO...HELP. Thanks
Clooney
08-11-2004 15:07:50
 Re: John Deere Model G, s/n 55272 in reply to jon, 08-11-2004 14:52:46
Jon, that "G" is an All-Fuel tractor.. It was started on gasoline [small tank] then switched over to tractor type fuel [kerosene, stove tops, distillate, thin heating type oil] once the coolant temperature was above around 180�..
It is NOT a diesel & won't run worth a hoot on diesel oil..
That "G" will run just fine on gasoline instead of tractor fuel..
For all practical purposes it is just a low compression gasoline engine with a carburetor & ignition system..
[email protected]
