Deere 420/430W bush hog size and weight?
Larry Alley
08-10-2004 20:11:19
I have a 1959 430W 5 speed non live power. Have had a few people tell me that these tractors will handle a 6 foot bush hog type mower. I have been shopping for a rotary mower and the Woods BB72 weighs around 1150 pounds. Was wanting to know how heavy of a mower the tractor could handle without straining it? A couple of dealers have told me a 5 foot would be better for the tractor than a 6 foot. I will only be using it to clip pasture, not using it in heavy brush. Also, I would like to find a good used bush hog type mower within 100 miles of Knoxville, Tn. Thanks, Larry.
Larry Alley
08-12-2004 13:08:30
 Re: Deere 420/430W bush hog size and weight? in reply to Larry Alley, 08-10-2004 20:11:19
Thanks to all of you who responded, Larry
slim
08-11-2004 10:43:58
Have a 1956 JD 420. We always used a 5 foot cutter on our pastures. When stuff was tall the 5 foot was all the tractor could handle. If you are only cutting low grass like in a yard situation, it could probably handle a 6 foot cutter.
slim
Hayfarmer
08-11-2004 07:28:35
I use a 5 foot King Kutter on my 430 U. In thicker or taller weeds it is all it wants. You may be able to handle a 6 foot in some situations but sometimes it may be heavier so why push it? Be sure to get an overrunning clutch for pto shaft or the mower will push you around the field.
Wayne in Tn.
08-11-2004 15:34:48
 Re: Deere 420/430W bush hog size and weight? in reply to Hayfarmer, 08-11-2004 07:28:35
I have been using a 6 ft. bushog behind 40, 420 and 430 models for over 30 years, no problems. As mentioned, the override clutch is the way to go if you don't have live pto. One thing that makes it eaiser on the tractor and lift, is not using the center link. That way you don't constantly have to lift the whole machine, just let the tail wheel stay on the ground and adjust the height at front with the lift. If you have rough, uneven ground or terraces, this method works good, it lets the tractor and bushog "bend" in the middle. If you do want to lift the whole bushog, you can use a short length of chain, instead of the centerlink.
