4020D loader problem
farmerherron
08-10-2004 17:10:28
I have a '64 4020D Synchro with a new 721 John Deere loader and 2 way control valve. The hydraulic pump has been rebuilt this summer. The problem is the loader shutters or even stops lifting, dumping, etc. after only a couple minutes of lite use. I opened the vavle the loader runs on up to maximum flow, changed the trans/hydaulic filter, oil is at proper level, and I cleaned the oil cooling radiator out. No change. Any help would be appreciated. Thanks
Gerald J.
08-18-2004 21:20:34
 Re: 4020D loader problem in reply to farmerherron, 08-10-2004 17:10:28
There is a check valve in the transmission that is supposed to keep the front reservoir from emptying back through the transmission pump when the transmission isn't turning. That wears out. Its a pain to replace, but there's a JD Service Information that says to convert the elbow right behind the transmission oil filter into a check valve. The parts from JD cost about $15. I have some sketches and the part numbers on my web site,>Link
I return the loader valve to the transmission oil filter cover. JD makes one for the purpose listed as a 2640 part.
Gerald J.
Glen Anderson
08-13-2004 00:15:51
I'm not sure if you found the answer to your problem, but if you haven't I'd be happy to give you any advice I could. I recently went through the same problems you are experiencing now!
You can contact me at [email protected]
chris
08-11-2004 20:35:10
Did the dealer say anything about the tractor not handling the hydraulic flow? Did you happen to clean the suction screen in the trans? Seems like you have other problems. My 68' 4020 and a 148 loader doesn't have problems like this but then your cylinders are probably bigger.
farmerherron
08-11-2004 02:50:16
Thanks for all the info guys. From the way it sounds I may just switch the loader over to the 4440 Power Shift.
Jason Z in MO
08-11-2004 13:24:14
 Re: 4020D loader problem in reply to farmerherron, 08-11-2004 02:50:16
One thought about the loader on a 4440 WITH a cab. Don"t know if your tractor does or not but if it does you might have to lean forward with the loader high. Stacking round bales up high can be frustrating due to the restricted visibity.
don"t ask how I know... :)
Gary in TX
08-10-2004 21:29:58
I had a 65 model 4020 diesel syncro with a 48 loader on it. pressure to the loader valve was supplied through the fitting on the side just under the the dash on the brake pedal side. The ell fitting that is just above the brake pedals was changed to a T fitting to allow pressure to the loader valve. The return line was plumbed into the hyd. filter housing/cover. Never really had any problems with it working. The 4020 was traded off but I go to keep the loader and we just put it on my 64 model 3020 today. Its connected to the rear scv's right now but will get an aux valve before too long. Other statements about the pumps and clutch usage is accurate. Just a note, I only traded the 4020 off because of a major clutch problem with it, now I have a 4430 with a 725 loader on it as well as the 3020 adn the 48 loader and my 4230 and 135 massey
Wynn
08-17-2004 10:34:36
 Re: 4020D loader problem in reply to Gary in TX, 08-10-2004 21:29:58
Gary - contact me if you are interested in a JD 2-function control valve kit - joy stick, mid mount quick disconnect box and all the hoses and fittings for the 20 through 55 series row crop tractors. We bought one before we picked up the loader in this discussion forum and found out later that the loader came with one. It is a "finished goods" part from JD and the dealer won't take it back - so I have one for sale - still in the box.
Gary IN TX
08-18-2004 05:56:53
 Re: 4020D loader problem in reply to Wynn, 08-17-2004 10:34:36
I don't know for sure but how much $$$$$ would we be talking about?????
Wynn
08-23-2004 10:05:38
 Re: 4020D loader problem in reply to Gary IN TX, 08-18-2004 05:56:53
The unit cost $924 plus $18 in shipping. How about $825 and I will cover the shipping?
Gary in TX
08-23-2004 10:20:50
 Re: 4020D loader problem in reply to Wynn, 08-23-2004 10:05:38
Hey Wynn,
Sounds like a not too bad a deal but some things have come up and will probably just have to run things the way they are or possibly have a kit added on to the note at the dealer? Kinda shaky times around here right now, mostly my nerves and sanity over anything else. :o)
Wynn
08-23-2004 10:35:45
 Re: 4020D loader problem in reply to Gary in TX, 08-23-2004 10:20:50
Good luck and I hope things go well. We will probably have the unit for some time so if things get better, feel free to contact me at [email protected]
RAR/IA
08-10-2004 19:15:45
Check with your JD dealer on the plumbing of the loader valve. If you are dumping back into the transmission case you will run out of oil as others state. You need to put it back into the charge circuit.
Roger in Iowa
Howard
08-10-2004 18:59:47
Not a good tractor to put a large loader on. IE: when you depress the clutch you also stop the transmission oil pump which supplies oil to the main pump.To overcome this problem, keep the rpm's up and your foot of the clutch as much as possible. You would be much better off with a power shift trans. that has a 'live' trans pump.Hope this helps. Howard
Hayfarmer
08-10-2004 18:25:52
Does this happen when you have your foot on the clutch? The transmission pump stops when you have you foot on the clutch and the main pump will eventually quit working if you hold clutch in.
Howard
08-10-2004 19:02:37
 Re: 4020D loader problem in reply to Hayfarmer, 08-10-2004 18:25:52
Yes, you are correct.
Howard
08-10-2004 19:08:01
 Re: 4020D loader problem in reply to Howard, 08-10-2004 19:02:37
Sorry, answered wrong message.
