2240 Front End Troubles
Scotty
08-10-2004 15:45:30
I am working on a 2240 with a swept back front end . I've got the rest of the tractor in good shape but the front end was about to fall out from under it so I replaced everything that was wore out and I"ve got everything in good shape on the front end now but I'm stuck on the big pin that the front end slides on when you go to roll the front back under the tractor, Well I got the old pin out but how do you get the new one in ! I have heated around the hole that the pin goes in and put the pin in the frezzer and tried to drive it in but don't have no room to swing and drive the pin in because the base pan is in the way....I just don't see no way to drive the pin in even if I take the oil pan off there still ain't enough room to swing a hammer! Is there anyway to squezze the pin in ? Thanks for your time and help! Scotty
david val
08-12-2004 00:36:12
 Re: 2240 Front End Troubles in reply to Scotty, 08-10-2004 15:45:30
if you have the old style pin (with a snap ring groove), you can install the pin from the front to the rear using a hydraulic hand pump with apropriate cylinder (or a long punch through the front bushing). push it until the snap ring groove is visible at the rear and install snap ring.
if you have the new style pin, (the one with a 'built un' shoulder in the middle), it has a tapped drilling on the front side so you can pull it in with bolts and washers. this pin is better since you can get from deere a special bolt and washers to secure the pin in it's place.
david
