3010 with Canopy - Need additional weight?
DJC
08-10-2004 09:20:04
My husband just added an JD steel canopy with posts (ROPS?) to his 3010 (row crop). He pulls a JD model 1008 10ft 3 point hitch rotary cutter on 12 acres with slight hills. He thinks he needs to add weight to his tractor now, for (rollover) safety. There is no water in the 13.9 x 36 tires, no weights (front-end or wheel) and the rear wheels are moved inside about 6 to 8 inches each. Would greatly appreciate any advice. Thanks.
G-MAN
08-10-2004 16:09:34
 Re: 3010 with Canopy - Need additional weight? in reply to DJC, 08-10-2004 09:20:04
That depends on how you define "slight" hills. Slight in one area can be pretty steep in others. If you have any doubt, I would move the wheels out to the widest practical setting that will still allow the tractor to get where it needs to get. I would agree with TBSCOTT that some front weight would be a good idea, particularly if the tractor happens to be a narrow-front. Wide-front tractors are of course inherently heavier out front, and don't require as much ballast up front. And the addition of the seat-belt is an EXCELLENT idea. I'd also check the overall condition of the seat assembly and make sure it is firmly attached to the tractor, and that the ROPS (also make sure it is a certified ROPS) is in good shape and properly attached. If your husband is an experienced and careful operator, there's a 99% chance he will never have a problem, but you always want to plan and prepare for that other 1%. The most important piece of safety equipment on any tractor is between the operator's ears.
TBSCOTT
08-10-2004 14:22:46
First thing is to add a seatbelt kit to the seat and use it!!! The tractor is more dangerous with a rops and no seatbelt then a tractor with no rops and no seatbelt in my opinion. Should at least add two starter weights to the front with 4 slab weights. these can be had pretty reasonable at least here in Michigan. Back weights can be optional. Be safe. :-)
