4020 Wont go into 5th or 7th
Farmall Don
08-10-2004 08:25:32
Early 4020 wont go into 5th or 7th and Im thinking a syncrinizer, but it would spin in all the top gears not the 5th or 7th only. What could this be then?
Thanks
DON
08-10-2004 09:21:38
 Re: 4020 Wont go into 5th or 7th in reply to Farmall Don, 08-10-2004 08:25:32
HUCKLEBERRY 1, 3,5,7 ARE THE SAME GEAR ON THE TOP SHAFT. 2, 4, 6, 8, ARE ALSO ON THE TOP SHAFT, GIVING YOU HIGH AND LOW RANGE. CHECK ADJUSTMENT OF SHIFT ROD, BUT MY GUESS IS THAT THE SYNCRONISERS ARE WORN OUT. THIS LETS THE SHIFT DRUM SPREAD AND JUMP OUT OF GEAR OR RAKING THE TEETH. THIS GRINDS OFF THE TEETH AND WONT LET IT SHIFT AFTER A WHILE. DON
Huckleberry
08-10-2004 09:04:34
My 3020 wouldn't go into 3rd and sometimes 5th. I found that if I first shift into the reverse of that range ~ then up into the wanted gear...it goes okay. no problem. This is not a true fix but it works. I've been running my 3020 like that for 2 years.
