JD A - front wheel questions
Ed Wagner
08-10-2004 07:17:52
Restoring a '46 A with the standard front pedestal (not Roll-a-matic). When removed front wheel hubs, there was 1/4" play back and forth on the axle. Could turn the nut tighter and take up this slack, but do I want to do that or leave some play there? Also, bearings look good, but the inner & outer race will fall apart and rollers fall out. Is this worn out?
Thanks for any help!!
BushogPapa
08-10-2004 11:27:45
 Re: JD A - front wheel questions in reply to Ed Wagner, 08-10-2004 07:17:52
Tighten with a 12" crescent wrench with about 10 lbs force on the handle, then turn ONE FLAT looser to have the proper setting... If it is only a fraction of a flat, that is just fine...there should be very little--if any--slop in the bearings... Tapered roller bearings are meant to have good allignment, and that happens only when there is next to no slop.. Ron.
1945 A
08-10-2004 08:22:00
You said the "races" fell apart---- do you mean the cages (that"s what secures the rollers to the inner race). The outer bearing race is what is installed in the wheel.
Yes, if the rollers fell off, the bearing is shot.
When you put the new bearings in, tighten the nut snug against the bearing, then, back off about 1/8-1/4 turn, install cotter pin, etc. Be sure to pack bearings with a good grade wheel bearing lube first.
