1940 JD H
Farm w/Junk
02-01-2004 20:32:41
Hi I am looking at a 1940 John Deere H. It has been sitting in a barn for years and is loose. Owner said it rolled over good and has good compression. Tin is excellent just needs screens grill is good. Needs a back rim and the other one is good but has wrong type rim on it. Near new tires, replaced before parked. Has pto. Hand start. What is this tractor worth? Is $1000-$1500 good, average, bad? Thanks for any comments. Matt
Mark Scholten
02-02-2004 05:13:22
 Re: 1940 JD H in reply to Farm w/Junk, 02-01-2004 20:32:41
Rear rims will cost you about $200.00 each. Are the rear tires the correct size? If not add another $350.00 for rear tires. I have seen good running "H's" go for $1000.00 and I have seen fairly nice painted up running but not ready for the show going for $3500.00
Good luck,
Mark
Farm w/Junk
02-02-2004 12:00:28
 Re: Re: 1940 JD H in reply to Mark Scholten, 02-02-2004 05:13:22
Mark thanks for your reply. I wish I could find H's running for $1000!!! I also have a 1939 with PTO I am fixing now hoping to get one of each year. I did get lucky and find a complete back wheel for $100. Thanks again.
Matt
JDVan
02-01-2004 22:11:43
I own a 1940 and a 1941 H and have had some experience with them. I would suggest you find out what it's going to cost you to find replacement rear wheels/rims before you make an offer.
Farm w/Junk
02-02-2004 11:57:05
 Re: Re: 1940 JD H in reply to JDVan, 02-01-2004 22:11:43
JDVAN thanks for your comments. Currently I have a 1939 H with PTO I am fixing up. I got a rear wheel complete used but excellent for $100 which is cheap. Hope I get that lucky again. I am hoping to collect an H of each year. Thanks again Matt
