G v/s GM
Rodknocker
08-09-2004 18:25:13
What are the differences between a model G and a model GM.
Thanks
G-MAN
08-10-2004 05:54:33
 Re: G v/s GM in reply to Rodknocker, 08-09-2004 18:25:13
It should be noted that the "G"s built immediately after the halt of "GM" production were physically identical to the "GM", with the only difference being the serial number tags. They retained the pan seat and forward battery placement. That's why there are technically four types of styled "G" - the "GM", post-war "G", the early late-styled "G", and the late late-styled "G" with the water pump.
Jon C -Florida
08-10-2004 04:25:04
Rodknocker -
The "G" technically began production in May of 1937 (for the 38 model year) and ran all the way through till 1953.
The "G" was one of the last to get "styled" by Dreyfuss in 1942. That year, the transmission was upgraded to six speeds, wheels,H.P. and tinwork changed and the "G" was reidentified as a "GM".
The "M" was for "modernized", and done to be able to get a price increase from the War Price Board that was established at the time of war.
After WWII, it was again reverted to the plain "G" or "new G".
Dougie
08-09-2004 19:51:40
A GM was made during 1941 to 1947. It had a steel seat and started by hand. A G was made from 1947 to 1953. Had a cushioned seat and came w/ a electic starter. Both wieghed about the same, had the same engine and horsepower. The GM was also made during WW2 so most of the war production GM's had steel wheels.
Paul in sd
08-10-2004 19:11:51
 Re: G v/s GM in reply to Dougie, 08-09-2004 19:51:40
acually probably fewer than 500 gm"s left the factory on steel wheels( maybe quite a few less than that.the first gms were built in 1941( 42 models) prior to pearl harbor.matirials werent that short yet.I think about 400 1942 gm"s. then twards the close of war materials became available and lions share of 44"s built had rubber. I have two of these 13230 on full steel and 13950 a 45 model shipped on rubber.Paul
