How much should it cost?
Toby
02-01-2004 19:29:59
I have removed the head from my 4240 and going to send it to the shop. I am looking for a possible crack and will do the valves and guides while there. What should I expect to pay for having the heads done? I am cluless.
Brokenwrench
02-02-2004 04:08:41
 Re: How much should it cost? in reply to Toby, 02-01-2004 19:29:59
Probably look to spend $4-700 depending on hours. You usually have to replace the valve seats and possibly some valves if the tractor has alot of hours on it. If the seats are cut and the valves ground,it drops the valves down in the head too far,which affects cold starting and performance. Make sure the shop has the proper specs.for a 466 head and machines it accordingly.
obo
02-01-2004 23:46:09
from experience- crack repairs on 466 heads don't hold very long. if such repair is suggested- demand a long term warrenty that covers oparation of engine in up to 220 deg.
obo
old
02-01-2004 19:42:56
Just a guess from haveing auto heads done, but if no new valves needed and no crack probably around $200 but if it needs valves $10 each and if it nees seats $10 each. The last 6 cylinder haed I had done (chev 250) cost me around $350. Hope this give you an idea of cost, but I have seen them get up to around $700 for major trouble
