4020 LP water in Oil!
J Klassen
02-01-2004 19:16:57
Have a 1064 4020 LP getting water in the oil. No seepage at weep holes, is it most likely a head gasket? Took head off and gasket dont look too bad. Tractor had sat for 2 years , full of antifreeze, just recently restarted it. When took head of a couple of cylinders had clearly had water on them as they were red with rust, again a sign of top end water leakage? Just trying to decide if pulling liners is needed or if a head gasket is the answer. All responses greatly appreciated.
old
02-01-2004 19:38:30
 Re: 4020 LP water in Oil! in reply to J Klassen, 02-01-2004 19:16:57
Rust in the cylinders could be from condensation since it hasn't run in a couple years. If it was me I would probably put a new head gasket on it and put some stop leak in the radiator and see what happens, the reason for the stop leaks is just in case it has a small sleeve leak which useing and heat might stop. Its what I'd call a $50 gamble, figureing $50 for parts to do the head gasket and stop leak, I'd only put water in it to start with unless its below 32 degrees where you are.
