Is a 60 a good choice for first JD
don
08-09-2004 09:53:04
I am looking to buy my first John Deere. I am leaning towards a 60, maybe a 50 depending on what I find first. 60's seem relatively plentiful. Are parts availabilty good for both? What are the potential trouble spots with them that I should look for?
Thanks
Clooney
08-09-2004 11:32:21
 Re: Is a 60 a good choice for first JD in reply to don, 08-09-2004 09:53:04
Don, both the 50 & 60 are a fine tractor.. They both have their strong & weak points.. I personally like the 60 better for field work but like the 50 better for playing around the drive & grading the road�
Both Mike M & Buickanddeere gave you some points to look at.. While the 520-530/620-630 are much better small work tractors with better hydraulics & comfort functions in most areas they are quite a bit more money..
When looking at the 50 release the clutch & try to lift the clutch pulley.. If there is a lot of vertical movement suspect a worn crankshaft [the 50 pulley bearing uses the crankshaft for the inner bearing race & when worn is difficult to repair].. Vertical pulley movement on the 60 isn�t such a big deal..
If either have power steering look for leaks [usually not too expensive to repair but in most cases a big job]..
Give the fan blades a push pull & look for more that about 1-1/2� of blade tip movement [that can also turn into a lot of work]..
Try all the trans gears & try to use all the gears to climb a steep hill [or pull something with the tractors] ,, [if either work their way out of gear suspect expensive repairs wil be necessary]..
If you expect to use the PTO�s see if you can try them on a PTO load before buying.. [excess noise or growling can mean very extensive teardown for repair]..
The best way to buy a 50 or 60 is right out of a farm field that has been working.. If there are a lot of paint-overs & repairs that show suspect a cover-up or the seller knows more than he wants to tell..
The best advise I can give you is to take someone with you that knows the old 2-cylinder Deere�s inside & out.. It�s real easy to fool a new Deere buyer but a lot more difficult to fool a seasoned used tractor buyer..
If you have any particular questions on either tractor just post back..
[email protected]
don
08-10-2004 17:27:07
 Re: Is a 60 a good choice for first JD in reply to Clooney, 08-09-2004 11:32:21
Thanks for all the information!!
Bob K - fan play clarific
08-09-2004 12:29:21
On the fan blade travel, 1 1/2" seems like an awful lot of play. My 50 only has about 1/2" play in the fan blades at the tip and it is pretty close to the correct lash/preload. I would be concerned about a fan that wiggles 1 1/2".
Mike M
08-10-2004 05:37:06
 Re: Is a 60 a good choice for first JD in reply to Bob K - fan play clarific, 08-09-2004 12:29:21
Some of the tractors with power steering will approch that 1 1/2 " figure and not be too worn out because of all the extra couplings. I once looked at a 620 that you could turn the fan about half ways around--now that's worn out.
buickanddeere
08-09-2004 10:53:17
If using three point hitch lean towards a 520/620. If you need a slow reverse avoid the 60 and go for the 50/520/620.
Mike M
08-09-2004 10:23:04
Both of those should have good parts availabilty.
Check for loose clutch drivers on the crankshaft,loose flywheels,look at the bottom of the block and head for any cracks welded up or patched spots. If you have live pto make sure it turns on and OFF and doesn't make any wierd loud noises. The transmission should shift good and not make any loud noises,or hear a rythmic click or clunk indicating a possible tooth broken off.
these are very hard to discribe in writing.
