420 W tom linkage adjustment?
Henry J
08-09-2004 08:53:15
Well I figured out the puzzle on the lashup of the load and depth control linkage on the 420W.
Now I have been lost in the book on how to set the length or what length the adjustment rod is set to. This is the link with the two rod ends on it. I had to disassemble mine to get it in working condition again. It looks to me like the length of the rod would vary considerably based on how far the rod ends are screwed onto the rod.
Can someone shed some light on this?
Thanx
Wayne in Tn.
08-09-2004 10:59:57
 Re: 420 W tom linkage adjustment? in reply to Henry J, 08-09-2004 08:53:15
Henry J. Unless you are going to be breaking land with a plow and need the load control to work, I would just disable it, by screwing the big nut-bolt on the rear housing out tight aganist the load control yoke, then adjust that linkage rod to where you have full travel of the control lever. This way you can still use a bushog, grader blade, ect. without the lift constantly jumping up and down. Also some of those 420's have a spring that hook in there on that linkage, that helps keep the control lever in the position you want. That spring is about 3 inches or so, long.
Henry J
08-09-2004 13:48:16
 Re: 420 W tom linkage adjustment? in reply to Wayne in Tn., 08-09-2004 10:59:57
Thanks Wayne
I had planned on locking out the load control but did not mention it. I will set the rod length up that way.
I have the spring and the L shaped bracket that came off it in a neatly labeled sack, but havn't figured out how to hook that up yet. I found the spring and noticed it in the parts book.
Thanks, and let me know if there is an easy to describe how to hook the spring back up.
Wayne in Tn.
08-09-2004 15:54:25
 Re: 420 W tom linkage adjustment? in reply to Henry J, 08-09-2004 13:48:16
Henry J. I will have to go out and look at some of mine to be sure if they have the spring. I know some did not come with it. I "think" one end hooks in the L-shaped bracket and the other end just hooks around the "tie rod" of that adjustable linkage rod....
