4320 Fuel Injection Pump
Wayne Wright
08-09-2004 08:51:57
Engine will typically start when cold but when turned off will not restart. Found that tapping on pump seems to allow fuel shutoff solenoid to engage and then engine starts. When cold you can hear solenoid clicking when key is turned on and off. When warm cannot hear it. Question: Can the top of the pump be removed and this solenoid be cleaned or replaced? What problems will I encounter? or does the pump have to be replaced? uggg
WTW
08-09-2004 10:26:34
 Re: 4320 Fuel Injection Pump in reply to Wayne Wright, 08-09-2004 08:51:57
Wayne, The top of the pump can be removed and with it will be the solenoid that you are questioning. Hook it up to a 12 volt battery and see if it is working. If not replace it. Good Luck, DW
