1950 john deere b
Ruben Pittman
08-08-2004 22:41:05
im wondering if anyone can figure out why my 1950 john deere b wont fire.me and my dad ran a wire from the battery to the coil (i think).i know the points open and close but aint fireing.im 17 and restoring it for are ffa chapter for parades so i dont know much about something that old
Clooney
08-09-2004 04:52:16
 Re: 1950 john deere b in reply to Ruben Pittman, 08-08-2004 22:41:05
Ruben, It sure would help to know if you have a magneto or a distributor on that "B".. An awful lot of those B"s had a magneto on them..
If your "B" has a magneto� oblong cap with the condenser mounted above the breaker plate then running battery power to it will hurt it.. [the Wico XB distributor had the condenser mounted vertical & under the points breaker plate].
If you have a distributor�either the round cap with an external coil,, or an oblong cap with an internal coil & power post sticking out of a screwed on plate on the front of it--then running battery power to it shouldn�t hurt it.
If it has a round cap [Delco] distributor with external coil & he ran battery power to the [non distributor side] of the coil then have him hook a test light to the other side of the coil & crank the engine over.. If the test light flashes on & off while cranking the engine your points are good & the wire between the coil & distributor are good so your problem is probably either a bad coil or bad plug wires or a fouled spark plugs..
If the test light doesn�t flash on & off while cranking you probably have oxidized points or a bad wire between the distributor & coil.. Try cleaning the points or replacing them [use a fine non metallic sand paper or points file to clean the points then drag a piece of clean white paper between the points].. On those round cap Delco distributors set the points gap to .022� on the high part of the points cam..
If you have an oblong cap internal coil Wico distributor you could very easily have a burnt out internal resistor [on the back side of that screwed on plate on the front of the distributor].. If you have that Wico XB distributor the first thing to do is check that resistor for being open, then check the points for oxidation [use the above Delco cleaning procedure].. [set the points to .015� on those Wico distributors]..
As mentioned above you could also have a Wico magneto on that tractor & if that�s the case DON�T ever run battery power to it.. If you think you might have a magneto instead of a distributor post back with the magneto description & we will then talk you through the troubleshooting procedure for that particular magneto..
Any questions just post back & we�ll be happy to answer them..
[email protected]
John T
08-08-2004 23:45:53
Ruben, if you want to do a good amount of dry boring reading lol on the subject of coil ignitions, their theory of operation and troubleshooting, e mail me and I will e mail you (If I still have them, I lost a bunch of files lately???) the final draft of 2 articles on the subject I had published in Green Magazine long ago. In the meantime, however, I will cut n paste a short n sweet simple method of troubleshooting an external coil ignition, part of which I posted here a few days back which may give you enough basic info to get you firing.
NOTE you spoke of a coil and a hot wire to it so the below is for a battery powered external coil ignition NOT a Magneto. If you have a Mag or a Wico XB battery powered distributor (which looks kinda like a mag and requires a hot switched wire to its terminal NOT any kill short switch set up like on some Wico Mags) let me know. THIS IS NOT APPLICABLE TO A MAG OR A WICO XB (Looks like a mag) DISTRIBUTOR, although much of the theory and points etc tests below could still apply, more mechanical differences is whats going on.
TROUBLESHOOTING A BATTERY POWERED EXTERNAL COIL TYPE IGNITION SYSTEM:
1) THE VERY FIRST THING YOU GOTTA HAVE is voltage to be present on the coils high supply (NOT to distributor) lil terminal when you turn the Ignition switch ON. If not she cant ever fire, but in the event the ign switch or circuit/wire down to the coil is bad, you can HOT WIRE it by jumping a hot ungrounded battery voltage source to the coils high input supply (NOT to distributor) side.
2a) When the ign switch is turned on, voltage should appear on the coils high input side. That would be 6 volts on a straight 6 volt system, 12 volts on a 12 volt non external ballasted system, or around 6 volts on a 12 volt system that used a 6 volt coil plus an external ballast resistor when points were closed and coil and all else works.
2b) To insure the coils low voltage primary winding is not bad/open, use an ohmmeter and measure its DC resistance between its lil + and -terminals. If its an open circuit (no continuity) its bad/open and will NOT work. It should measure around 1.2 to 2 ohms or so if its a 6 volt coil and maybe 2.5 to 3.5 if its a 12 volt internally ballasted coil. NOTE CAUTION have all leads and any voltage source unattached to the coil for this simple primary winding continuity test.
3) Next, place your voltmeter or test lamp on the coils other low to distributor terminal side, turn her on and crank the engine over.
4) A test lamp there should flash ON (when points are open) and OFF (when points are closed)
5) If the lamp never comes on there, the coils primary is bad/open (see above),,,,, ,,,,or the points are never opening,,,,, ,,,or theres a shorted/bad condensor (remove its lead to points and see if lamp comes on, if so, bad shorted condensor or its wiring),,,,, ,,or the points wire is shorted,,,,, ,,or the distributors side out pass thru stud is grounded (use ohm meter to test that when no voltage or wires are attached to it, i.e. see if the stud is permanently grounded to the distributirs frame, it can happen),,,,, ,,,or the points may have a shorted spring.
6) If the lamp never goes off as engines cranked, the points are not closing,,,,, ,,or the wire or circuit is missing from the distributor to the points or from the coils low side to the distributor,,,,,or the distributors not well grounded to the tractor.
7) She cant fire the coil unless its low side is getting a conductive ground return path via closed points and then the circuit is open when the points open.
AS THE POINTS OPEN AND CLOSE THE COILS PRIMARY CURRENT MUST BE SWITCHED ON TO CONDUCT CURRENT (points closed) AND OFF (points open). Thats whay a test lamp on the coils low to distributoir side MUST flash on n off to fire the coil
8) Be sure the condensor or its wiring is NOT shorted out and see if the lite comes on (when points open) with the condensor disconnected. If the light ON n OFF test works with the condensor removed (light will come on when points open) but it never comes on otherwise, the condensor or its wiring is shorted.
9) To check for possible cap or rotor problems (if all the tests above pass)..... .....
10) Remove the coil wire from the distributor leaving coil end inside coil and place the exposed end to within 1/8 inch away from tractor iron like block or head etc. Turn her on and crank her over and a spark should jump that gap nice n blue each time the points open. If so there but NOT out the plug wire terminals,,,,,the cap or rotor is bad. Check it for cracks or carbon traces etc. If the cap n rotor are good but the plugs dont fire, the wires or plugs could be bad. Try different plugs or wires and by swapping sides see if any plugs fire as she is cranked. If fire comes out the coil wire per the above but no plugs fire, its gotta be a cap or rotor or plug wire or plug problem. NOTE if its the right cap, when the points break open the rotor tip should be lined up next to one of the caps internal pickup points.
SUMMARY: Be sure the points open on high cam,,,,, ,theres voltage present on distributors high side at all times when ignitions on,,,,, ,voltage on coils low side flashes on and off as distributor is cranked,,,,, ,,,condensors not bad/shorted,,,,, ,,no shorts in wires to points and no shorts in pass thru side out distributor stud,,,,, ,, a good continuous wire from coil to distributors stud,,,,, ,,,coil has continuituy.
Good Luck n God Bless, e mail me if you want my Green Magazine Articles, post back or e mail me any questions and let me know what happens.
John T in Indiana [email protected]
John T (try this first)
08-08-2004 23:59:17
 Re: 1950 john deere b in reply to John T, 08-08-2004 23:45:53
Ruben, sorry its real real late and Im trying to answer these and all my tractor e mail questions and forgot some basics to try first.
FIRST; The points gotta be opening and closing as the distributor shaft rotates,,,,, ,,,gapped proper,,,,, ,,,,, ,NOTTTTT TT burned or pitted or carboned up or heavy gray oxide coated (replace if so). You might first take a look at them and file (only if necesssary) n clean n polish and gap them and if she fires then ,,,,, ,,,get a new set of points.
POINTS ARE FIRST THING TO SUSPECT IF SHE QUITS FIRING.
Ive has many not fire and simply passed a shop cloth between the points to remove the oxide build up and they fired. If burned or carboned or pitted bad, then a point file and re gap may make em fire, but still get a new set. NOTE a bad (like a pure open) condensor can make points burn up much quicker. However, if its dead shorted (or it or points wiring) she cant fire at all
CHECK THE POINTS FIRST AND IF THEY ARE GOOD, PROCEED TO MY TROUBLESHOOTUGN BELOW.
John T Let me know
Pappy
08-08-2004 23:03:42
Ruben---read down about three or four posts and read about the John Deere "A" that is not firing.
John T has written some words of wisdom.
Ruben Pittman
08-08-2004 23:17:37
 Re: 1950 john deere b in reply to Pappy, 08-08-2004 23:03:42
i dont know if this makes a difference i know mine dont have a magneto its got a foot starter,it has a delco (i think) distributor,the guy at napa said that it had been converted.and he could get points if thats my problem. but i dont know a hole lot about these old things.thanks for any help,Ruben
