How to adjust the clutch (shims) on my 520 and oth
Tyler--MO
02-01-2004 18:42:07
Hello again,
The 520 LP is slowly progressing. I put the LP tank and dash assembly on today. It's beginning to look like it might actually run soon...hopefully. I do have a few questions that I haven't found 100% answers for as of now.
~I have the clutch adjustment type that uses external shims to control the pulley brake and to keep the clutch from re-enagaging as the lever is pulled back. My question is...how do I know where to begin with the shims and what do I look for. My 720 service manual is pretty vague on what to do.
~How do I know where to install my distributor correctly. I don't have the flywheel cover right now...it's in the body shop...so how to I time the engine correctly. Is it as easy as an old 350 chevy with pointint the rotor toards #1 at TDC....?? And at TDC where are the pistons suposed to be?? I guess I guess also I need to have the valve cover off to find when the intake and exhause stroke on #1 is so it fires b4 the exhause and not intake....Well I guess I just need some common sense help on this one.
Thanks for any technical assistance. Tyler-MO
Clooney
02-02-2004 03:28:16
 Re: How to adjust the clutch (shims) on my 520 and in reply to Tyler--MO, 02-01-2004 18:42:07
Tyler, on your clutch pin shim adjustment?.. you say��I have the clutch adjustment type that uses external shims��>>> By that I presume you have the external stop plate with the shims under it & not the earlier type with the shims around the inner pin?
~It really doesn�t matter for adjustment but does on how you change the shims & shim height..
~It will be next to impossible to set the clutch stop shim height if you have a lot of wear or play in the clutch fork shaft or clutch linkage pins & hand lever..
~With the above in mind start by backing the pulley brake adjuster off until the brake is plenty clear of the pulley with the clutch disengaged� Then adjust the clutch until you get the proper snap-in & lever force to engage the clutch� Then snap the clutch out & let the lever stay in the disengaged position, don�t pull it all the back to the brake position. [If you have a lot of clutch shaft & linkage wear it will be hard to determine disengaged from the brake position]� With the clutch hand lever in the disengaged position [not all the way back to the brake position] the clutch pulley should spin freely & the clutch pulley should have about 1/16�-1/8� in & out [lateral] movement.. If you have too much [or not enough] in & out movement of the clutch pulley add or remove shims until you have the proper 1/16�-1/8� of pulley movement.. If you have a loose clutch lever, or worn linkage, or worn fork shaft parts you will just have to wing it until the pulley brake works correctly..
~When the pulley stop pin is set correctly re-adjust the pulley brake so when you snap the clutch out the pulley can still spin on it�s own & the brake stops the pulley when the hand lever is pulled all the way to the rear..
~On your distributor?� Remove the L/H spark plug, then rotate the flywheel in the starting direction until you start to feel compression on the L/H plug hole, then continue rotating until the flywheel slot is running fore/aft [parallel with the ground] or use a wire in the L/H plug hole & feel for absolute TDC on compression on the L/H cylinder.. Once the L/H cylinder is at TDC compression just install the distributor in the correct orientation & with the spark rotor pointing to the L/H cylinder plug tower.. That should be close enough to get it started, then once started use a timing light on the L/H plug wire & point it through the flywheel cover�s timing hole to set the timing [I think it�s 20� btdc at fast idle on the LP but I would have to look to be sure as it could be 15�btdc]�
~Any questions just post back or E-Mail..
[email protected]
