JD 435 Parts needed
435GM
08-08-2004 06:26:37
I'm looking for the following 435 parts. Any help with possible sources would also be appreciated.
1. Front end support casting that bolts to the engine for a regular front axle. Casting# T11861T
2. Hydraulic pump for a tractor with power steering. My parts books lead me to belive that one off of a early 1010 (up to sn# 024694) will work if I machine a new input shaft.
3. Support bracket for the power steering control valve. JD part #AT11547T
4. Nice unrusted fuel tank.
Henry J
08-08-2004 08:55:03
 Re: JD 435 Parts needed in reply to 435GM, 08-08-2004 06:26:37
435
A long time ago I read an article in the Green Magazine about those ps pumps being made of unobtanium.
I don't know what the screamer had for a ps pump but suspect that it may be the same as a late 420/430. As I recall, the article indicated that the pump was about the same as the old GM pump like in the late 50's/early 60's.
Just another thought, I just overhauled one that had the small cap on top and the parts minus one little seal were available at JD. They even had a kit that was a replacement for the pump itself for the ring, rotor and vanes in the pump.
I am hesitant to advertise for other people, but if you email me I can give you a source that should have the front end support at a reasonable price or could put you on the trail of one.
good hunting
[email protected]
