4020
Monty
08-08-2004 06:08:09
I was bushoging yesterday and I got into a ditch which made the tractor bog down. I guess the slip clutch didnt slip and i just pulled the pto lever back before it stalled. Pto is fine but the tractor has developed a sputter and a lack of horse power. Almost sounds like a dirty fuel filter or air in the fuel system what does everbody think whats wrong any help will be appreciated thanks
msb
08-08-2004 13:08:08
 Re: 4020 in reply to Monty, 08-08-2004 06:08:09
Jolt probably did knock loose some crud in the filters and or the transfer pump on the side of the engine.Replace the filters, clean the sediment bowl and check to see that you have a full flow of fuel coming from the tank.Could also be water that got stirred up in the fuel.NOT GOOD!Open the drain in the bottom of the tank to eliminate any water in the tank occasionally.
