3010 wiring diagram for fender imp.light's -1963
Shannon
08-07-2004 19:37:10
I need a wiring diagram for the light switch & harness for the fender & imp. light's.Any help will be much appreciated. Shannon.
msb
08-07-2004 20:17:46
 Re: 3010 wiring diagram for fender imp.light's -1 in reply to Shannon, 08-07-2004 19:37:10
Splice in a wire on the red wire going to the rear work lamp and install a flasher on the fender mount bracket.You may have to remove the toolbox to get to the wiring harness.
msb
08-07-2004 20:20:27
 Correction: in reply to msb, 08-07-2004 20:17:46
splice the wire into the wire going to the red lamp.Not sure but I think it is the white wire.Turn the red light on and use a test light to see if I am right or wrong.
