3020 jumps gears, etc.....
RobG
08-07-2004 18:24:40
Our 3020 pops out of 5th and 7th if any load is applied. It seems ok in 2nd and 4th. I can hold the tractor in gear if I put maybe 10 pounds of resistance on the shift lever. I am looking at maybe restoring this tractor in the future but will hesitate to do so if I am facing a major issue in the transmission. The tractor has about 3300 hours.
Also, is there an interlock between the transmission and the starter button on this tractor? I was told the starter button has been replaced but I still have to jumper across the starter to light the beast up.
Finally, I would appreciate hearing about members" experiences with various tractor modifications...oversize pistons, cold manifolds, electronic ignitions, cams, etc., if they were verified by dyno measurements. I don"t have a dyno and have no practical access to one, so I can"t readily participate, much as I would like to. I was just reading one of the posts by an intrepid soul building a dyno and was thinking how it would be great to see the results of the modification efforts of those who can obtain power and torque data.
My $0.02 worth.
Thanks and have a great day!
Rob
msb
08-07-2004 20:07:32
 Re: 3020 jumps gears, etc..... in reply to RobG, 08-07-2004 18:24:40
Sounds like the shift lever is out of adjustment.That could also account for the neutral switch not letting the tractor start with the starter button.Does the shift lever just about hit the dash when it is shifted into park?Does the shift lever line up exactly on center with each shift station?i.e.1-3-R,2-5-R,4-7,6-8?Jiggle the lever to see if the detent is in its hole before moving the lever sideways.If the adjustment is off, shift the tractor into 5th and watch to see which shifter arm moves on the right side of the transmission.Remove the pin from the yoke attached to that shifter arm and with the shifter and the transmission in neutral lengthen or shorten the yoke until you have the lever in the center of the quadrant or slot.Replace the pin and tighten the jamb nut.Check it in each range and fine tune the adjustment.The neutral switch is also located on the right side of the transmission.It looks like a big nut with two wires attached.Check it for a good connection.If the tractor still won't start then jumper the connection to rule out problems elswhere.BE CAREFUL.DON'T GET RUN OVER!IF it starts with the jumper then remove the neutral switch and remove one shim/washer on the stem.Or sometimes the shiter arm gets loose and won't let the switch make contact.In that case,loosen the shifter arm and tap on the arm.That should be enough to get the shifter arm back in its proper position.Then retighten the bolt.
Les Bolden
02-20-2005 19:23:50
 Re: 3020 jumps gears, etc..... in reply to msb, 08-07-2004 20:07:32
Could this be the solution to a problem I am having with a 2010JD that will not go into 3rd, 5th, 7th, or 8th? It will go into the reverse gears and function properly, but only grinds and doesn't seem to ever engage in the gears when trying to shift into those gears.
Any suggestions?
RobG
08-08-2004 19:54:08
THANKS! I'll give this a shot.
ROB
