4020 Steering problems ?
JD720
08-07-2004 18:19:37
I hit a stump and broke the right spindle.I replaced the spindle but now it will not turn to the left.when you try to turn it to the left you can hear the engine pull down just a little.If you raise the frontend and keep working the steering wheelback and forth you can eventually get the wheels all the way to the left.Would the problem most likely be in the steering motor or the valve? Any help is appreciated thank you
msb
08-07-2004 20:38:59
 Re: 4020 Steering problems ? in reply to JD720, 08-07-2004 18:19:37
Didn't buckle a tie rod end did you?It is most likely the motor has a blown o ring or o rings.Where is my shop manual when I need it?lol,bob---If no one else comes along maybe I can help you tomorrow.Can't remember exactly what that motor set up looks like.There is a drain----
david val
08-08-2004 03:08:53
 Re: 4020 Steering problems ? in reply to msb, 08-07-2004 20:38:59
to check steering motor leakage, remove the thin rubber hose that connects the motor steering to the oil cooler at the cooler and plug the cooler opening. run the engine and rotate steering wheel. there should be very small or no flow from the hose. if there is a flow of oil out of the hose while turning the steering wheel the steering motor is leaking.
david
