Fan assembly on an M
weblvr
08-07-2004 16:06:03
I am restoring my Model "M" and tore the fan assembly down for cleaning, painting, etc.. Great engineering on that gadget. My question for the group is what to lubricate it with? None of my books have an answer, but it appears to be mebbe an 80 or 90 wt.. Really thick stuff. Thanks in advance.
weblvr
08-08-2004 09:43:12
 Re: Fan assembly on an M in reply to weblvr, 08-07-2004 16:06:03
Thanks, Mike. I will probably have the same issue with the seal, so thinking mebbe using some thick stuff anyway which probably won't hurt it. There appears to be a groove for an O ring on the shaft, actually two of them, which I will explore. This is a great group!
Mike M
08-07-2004 17:01:49
I think the owners manual says to use engine oil fill to the level of the filler hole when it is horizontal. If your oil seal is worn out like mine was I had enough shaft sticking out the back to expoxy a thin regular type oil seal on the back this has been a few years ago and it has worked real good.
