Broken bolt from frame to block
Butch ( PA )
08-07-2004 14:17:06
Now I've really done it guys. In my zeal in tightening the block to the frame, I broke a bolt off from the frame. Is it possible to replace this stud bolt without removing the block again? I feel like a dolt doing this.
Greg S
08-09-2004 12:53:01
 Re: Broken bolt from frame to block in reply to Butch ( PA ), 08-07-2004 14:17:06
There are many ways to remove broken bolts. Somebody already mentioned welding a nut to the broken part of the bolt, and then simply turning it out. This method has been helpful to me as recently as yesterday! Some other ideas might include:
* Use a die grinder with a small diameter cutting tool on it and grind a slot into the exposed end of the broken bolt. Then use a screwdriver to remove the bolt.
* Buy a left handed drill bit and try to drill it out. Sometimes, the drill will catch on the bolt, and simply screw itself out. Be sure to use a puch to start the hole in the center of the bolt. This will become more important if you need to go to the next step.
* If you wind up with a hole all the way through the bolt from using the LH drill, then try a #6 easy out. A #5 might work, but is more likely to break. You probably will not break the #6. Be sure to presoak the bolt with some kind of penetrating oil such as PB Blaster for a day or so ahead of time.
* If this doesn't work, then continue step drilling until you just touch the ID of the threads. This is why it was important to center your hole in the first place. Now retap the hole. If the hole in the bolt is slightly off center, don't worry. It will probably be OK.
* Most likely, heating will not help. The cast iron that is actually holding the bolt is not exposed enough to heat.
* Plunger EDM. This requires that the block be removed. EDM will also remove a broken drill bit or tap. At this point, I would probably evaluate waht I am using the tractor for, and how important that one bolt really was.
Dave K
08-08-2004 10:46:45
I would suggest a good torque wrench be used next time!! DO NOT use an easy-out, break that and you really have a problem. I have had some luck by drilling out a snapped bolt and retapping the hole.
Dave
msb
08-07-2004 20:13:35
Is it possible that you can weld a nut on the broken bolt? IF so,it should back right out with very little force
Pappy
08-07-2004 22:36:20
 Re: Broken bolt from frame to block in reply to msb, 08-07-2004 20:13:35
If the bolt is bottomed out in the hole, you are in for a long afternoon. If the bolt was properly lubricated and you just stressed it until it broke, it might come out. I have removed them by striking the broken bolt with a punch to loosen the tension on the threads. By doing this, the bolt should not be binding in the threads and you might be able to work it out.
