F935
Dug
08-07-2004 13:29:50
Looking at an F935. Two big questions: What is one worth. This unit has 2400 hours, early 90s model, dual tanks, 22 hp dsl, 60 inch deck. Service record is perfect!! Asking $3,600!
Second, how will this perform on slopes? I will use it around my pond and have 35-40 degree slopes. Been push mowing and it's getting old real fast. If this machine won't perform well on that kind of slope, what would you recommend?
Thanks in advance for your input,
Dug
Jerry
08-08-2004 06:27:48
 Re: F935 in reply to Dug, 08-07-2004 13:29:50
I had the same problem with my F935 concerning the rubber torsion joint.Replaced it 3 times,the 4th time I cut it out and replaced it with a $25.00 u-joint and that was 4 years ago...problem solved,other than that best mower I ever owned.
Jaker
08-07-2004 15:16:03
Dug,
We have both 1145 4 wd drive and a 935 2 wheel. The 935 has a 72 inch deck with about 2600 hours. The engine has been problem free so far. We have had the 935 since it had 1100 hrs. We have replaced both pto shafts( one on deck and main shaft the runs the length of the machine, pulley on main pto shaft. At last count we have replace the rubber torsion joint that joins the engine with the hydro at least 3 times. Other than that not too many problems. With the 6 ft deck I am going to say it is extremely difficult to tip one of these over is speeds are kept slow. I am not going to say they won't go over but it would be difficult. The deck will actually serve as "wheelie bars" so to speak. I have had the left front wheel off of the ground as far as 14 inches between the bottom of the tire and the gorund. The machine did not even feel as it wanted to go over. Keep the safety kill switch hooked to the seat that way you don't go moving around on the seat to accomadate for the slope. I have no idea how well the 5 foot deck will work in this situation. I know the 22 hp will be enough power on grass that is mowed like a yard but not for bushhogging.
The yanmar are hard on fuel compared to their orange competition. The yanmar will use about twice the amount of fuel. I would say if the machine looks as nice as the records have been kept than 3600.00 is a good price. Most likely you will never wear the machine out. Jake
Dug
08-08-2004 08:23:12
 Re: F935 in reply to Jaker, 08-07-2004 15:16:03
Thanks for the input, Jake. I am planning on picking it up today!
Dug
