Ernie, Sorry, Im unfamiliar with the 1520, but on many elec conversions for battery powered coil/distributor ignitions, you simply remove the points and condensor from the distributors base plate,,,,, ,,place a ring with magnets on/over the distributors shaft/cam,,,,, ,,,mount a pick up coil/unit on the base plate which replaces the points and condensor,,,,, ,,,run two wires out one to the each side of the coil,,,,, , and youre good to go. NOTE THIS IS JUST A TYPICAL INSTALLATION, IT DEPENDS ON THE UNIT HOW TO WIRE. While you can still use the old stock coil and still get some improved perfromance, to get the most bang for the buck, replace the coil with a high energy high voltage performance type and run a wider plug gap. Check with the vendor if you use a high performance coil as to any plug wire recommendations. CAUTION match the elec igniiton with what ground youre at (+ or -) or you may have to convert, check that out with the vendor. If that tractor had or was replaced with any ballast resistors, check out the coil voltage. Post back or e mail [email protected] any questions. Most elec ignitions are not hard to install at all. Good Luck n God Bless ya Ernie John T [email protected]
