No Shut-off Solenoid
ags
08-06-2004 18:20:31
The Marvel-Schebler carb on my 1020 was replaced with a Zenith Carb. There is no shut-off solenoid on it and I get some deiseling. Is there a way to get a shut-off solenoid on this carb?Their are two sets of numbers on the tag on the Zenith carb 999 and 14996A.
mowr
08-07-2004 15:03:58
 Re: No Shut-off Solenoid in reply to ags, 08-06-2004 18:20:31
Make sure the idle speed is set at the minimum recommended in your manual. It also helps oftentimes to richen up the idle mixture a little; more fuel evaporating helps cool down the glowing carbon that is igniting the fuel.
ags
08-08-2004 05:58:59
 Re: No Shut-off Solenoid in reply to mowr, 08-07-2004 15:03:58
I have it idled down about as slow as it will go without stalling. I'll try making it a little richer .thanks
msb
08-06-2004 20:16:55
Try idling the engine for 3 minutes before you try to shut it off especially after working the engine a bit.Its possible that is all you will need to do.I think there are several applications of the solenoid that were used on a Zenith.Try a 55 corn special combine model equipped with a 303 gas engine.If my memory serves me correct that model used a solenoid on a Zenith carb.
ags
08-07-2004 07:30:55
 Re: No Shut-off Solenoid in reply to msb, 08-06-2004 20:16:55
your right about letting it idle down before shutting it off,it works most of the time but still does it occasionally.I'll check out the 55 corn special.Thanks for the tip
