430 lift oil type??????????????
Deere Heaven
08-06-2004 15:25:41
I am needing to refill the lift pump in my 430, but I dont know what type, straight 30? thanks, Brian Nielsen
CPeter
08-06-2004 18:24:55
 Re: 430 lift oil type?????????????? in reply to Deere Heaven , 08-06-2004 15:25:41
If you can't find the 10wt NON detergent oil, I found non foaming SAE 10wt hydraulic oil at Home Depot. It seems to have quited down the noise in my 420 hydraulic system. DO NOT use modern detergent types of oil. They will mix with any moisture and foam. This causes the pump to cavitate and makes for vibration and nose in the system. NON detergent oil and water will not stay mixed and the water will settle to the bottom.
Wayne in Tn.
08-06-2004 16:21:05
Brian,The manuals say use 10w or 30w Non-Detergent motor oil. This is the cheap stuff at Wal-Mart, ect. I usually use the 10w as it seems to help line viberation. Some of the modern hydraulic oils can cause problems in those old systems. Also this system does not have a filter. I have had good luck just using what they did back in 1959.
