720 conversion to alternator
Mike Corbett
08-06-2004 14:37:33
Can anyone give me some advice on how to convert my 720 POSITIVE GROUND from a generator to an alternator. My current generator does not keep my battery charged and I'm hoping a conversion to an alternator will give me more output and solve the problem. Thanks for any help out there.
Mike Corbett
[email protected]
Mike Corbett
08-08-2004 13:39:48
 Re: 720 conversion to alternator in reply to Mike Corbett, 08-06-2004 14:37:33
Thanks for the input. The conversion sounds so simple, but I'm worried about the positive ground. If I change the system to a negative ground to use the alternator, won't this affect the starter? ie: cause the starter to turn in reverse? The existing generator is "putting out" but not enough to keep the battery charged. I use the tractor on a small farm, often at low speed. I'm not concerned with "restoration" but with keeping it running so I can work my fields. Thanks again for your input and help.
Mike Corbett
[email protected]
Gouldbusk, TX.
buickanddeere
08-08-2004 19:16:10
 Re: 720 conversion to alternator in reply to Mike Corbett, 08-08-2004 13:39:48
Diesel electric start or cranking engine. Or a spark ignition gas,LP or all-fuel engine? The 6V generator would makes 20 amp, the 12 generator 20 amp and the 24V 10 amp stock or 18amp with the late 840 24V generator windings. Deere engineers wanted the engines to run at full rated rpms and at 80% load. This was to reduce wear from lugging, improve fuel efficency and promote clean burning. The diesel made 265 lb ft or torque at 1125 and increased to 303 lb ft at 750-800rpm.
George S. in the real NY
08-08-2004 05:31:51
I changed my 720 to alternator back in '85, shortly after I got it. I used a GM alt with external regulator, put a diode in the ign wiring some where, and swapped the leads on the ammeter. Worked fine ever since. You have to make a new bracket as the distance from the center of the belt to the mounting ear on the alt is different than on the generator. That is a point that all too many conversions miss and the belt runs crooked. All this was before the days of restorations and correct police. By using neg gnd, you can use radio for tunes for the operator, a two way radio and monitor on your corn planter without the hassle of isolating the device. I mounted the regulator on the back side of the bracket that holds the power steering pump. I used the external regulator set up as I was told that the GM internal alts drew some current while the engine was off, which is not good for a tractor which is stored for many months. Probably J.T. and Clooney will have more words. You should also check the archives as this topic has been up here many times.
buickanddeere
08-08-2004 11:38:38
 Re: 720 conversion to alternator in reply to George S. in the real NY, 08-08-2004 05:31:51
Swap two pairs of wires and any generator equipped two cylinder and New Generation will operate negative ground.
F-I-T
08-07-2004 08:16:22
Mike:
What is wrong with the generator? Maybe you just have a brush problem or a poor ground. Is it a gas tractor with a 12 system? That's what I imagined since you're talking alternators.
There are a lot of folks here (not ME!) that can help you get the generator up and running.
Do you have any output at all? Is the belt tight? Do you tend to run the engine at lower speeds? If so, some folks install a smaller pulley so the generator spins faster, thus keeping the battery up. On our old loader tractor, we would wire it in the winter to a straight through scheme so the generator had full output at all times, hence the battery would stay up better.
Let us know the details and someone will help you out.
Frank
