Bearing Preload?
SB in AR
08-06-2004 13:55:43
OK, while reviewing my service manual, I noticed something that has perplexed me. How do you measure bearing preload? The service manual, in reference to replacing the front wheel bearings & seals (as well as numerous other places), says that bearing preload should be adjusted to 0.000 - 0.003 by varying the number of shims used. OK, I know how to adjust the preload, but how do you measure it?
msb
08-06-2004 20:27:38
 Re: Bearing Preload? in reply to SB in AR, 08-06-2004 13:55:43
Easy. Simply measure the end play at a specific point of castellation.Then tighten up the nut one castellation and measure the end play.The difference will give you a reference to use.One castellation equals .00X" difference.It won't be an exact science but it will be close enough.John Deere engineers always said to take all the end play out of the axle and then tighten the nut one more castellation.There should be a slight drag on the wheel bearing and some minor peening of the bearing is normal wear on a bearing.
Henry J
08-06-2004 15:08:20
SB
I have never worked on wheel bearings that were shimmed.
On the preload of 001 to 003 as you mentioned, put the bearing together with shims that will guarantee you some end play. Take a dial indicator and measure the amount of end play you have - say it was 010. Now if you took out 010 you would be at zero (000) preload. If you took out shims to equal 013 and put it back together you would have a snugged up bearing with a preload of 003.
G-MAN
08-06-2004 14:50:58
Some bearings are preloaded to produce a specific rolling-drag, which is the torque required to turn whatever you're preloading. Some bearings are preloaded to provide a specific endplay, which when you think about it, isn't preload at all. You'll probably have to use a dial indicator to measure end play, or just go by feel.
