John Deere G Starter
JohnDeere2Cylinder
08-06-2004 12:38:46
Howdy. I would like to change my starter on my 1950 JD G to the new, lighter, gear reduction starter with a key switch or push button. Any experience on ordering the right NAPA starter and getting everything to work? (I want to lighten up my Puller.) Thanks.
G-MAN
08-06-2004 13:28:01
 Re: John Deere G Starter in reply to JohnDeere2Cylinder, 08-06-2004 12:38:46
Deere part number TY24439 will bolt on and work. $400 list from Deere. A parts store might be able to cross that number. It's a Denso unit. The weight is around 25 lbs.
Ol Gray A
08-06-2004 18:17:28
 Re: John Deere G Starter in reply to G-MAN, 08-06-2004 13:28:01
Will that starter fit a 1951 JD A?
JDGnut
08-07-2004 10:17:25
 Re: John Deere G Starter in reply to Ol Gray A, 08-06-2004 18:17:28
On the A's it will make a difference.. it is a top mounts starter almost any of the late model starters will work... (they do need to be the 3 bolt pattern for a small block Deere..) I think every starter I have has a different part number and they all fit on my G's and top mount A's... some are gear reduction starters.. some are straight drives.. on the reduction.. there are different part numbers for different angles of the offset for the motor of the starter.. but all I have tried have fit the G's and top mount A's..
Good Luck
JDGnut
