JD H
Ed Florida
02-01-2004 16:35:38
Just got a JD H 13918 and I cant get it to run. New plugs, plenty of spark, fuel up to the carb. Doesn"t seem to get to the cylinders. Its hand start and I'm pooped. Any help out there for a newbe please. Tx Ed
buckeye al
02-03-2004 14:27:10
 Re: JD H in reply to Ed Florida, 02-01-2004 16:35:38
You have lots of good advice from others to go on. Thought I'd offer a pair of pennies from a diffeerent approach. We had this same trouble with an H years ago. Pull it & it would start right up but hand cranking seemed to be pure luck if it ever started. Good spark, good plugs, new plugs, new gas, old gas, cup on air cleaner, cup off the air cleaner, nothing seemed to make any difference.
Turned out the choke relief valve (or whatever you call it) was broken. There is an oblong hole in the choke plate that is supposed to be covered by a spring loaded plate on the back or engine side of the choke plate with the choke closed. If that is missing or if the bottom of the flap is broken off or if the spring is missing they won't start worth a hoot! Something simple to check on! Remove the air intake pipe & take a peek in there with the choke pulled out & see what's there..... or maybe not there. I made a new one out of some sheet metal somewhere 'round 35 years ago. That part is still in service.
Jason D. Wahl
02-02-2004 10:27:29
You're in Texas? Where at? I live in New Braunfels, and could help you if you're near.
Clooney
02-02-2004 03:58:48
Ed, you could have about anything from a non working choke, to low compression [non sealing rings], to sticking valves, to a plugged up carb, to something assembled incorrectly by the last owner.
~I guess the place to start is to open the carb's drain cock & make sure you have gasoline flowing out of that [if not suspect a stuck carb needle].
~If you have gasoline in the carb's float bowl then you at least have fuel that far..
~Next remove both spark plugs & squirt a little gasoline in each plug hole then re-install the plugs & see if it will try to start or even pop.. [if it pops & tries to start then suspect a carb choke problem or rusted or varnished up carb inside].
~If it won't even pop with gasoline squirted into the cylinders take a known good spark plug & open the plug gap to 3/16" [use a 3/16" drill bit as a gap gage],, then install that in one plug wire at a time, & lay it on the engine block, then crank the engine,, if you get a bluish colored spark to jump that 3/16� gap multiple times in a row your ignition system is good.. If you can�t get a good spark to jump that 3/16� gap your ignition system needs attention.. [clean the points or replace them & clean all the rust from inside the mag]
~If you have a good spark per above & fuel Inside the carb then try new spark plugs..
~Next try turning the flywheel & listening for the mag to snap as the L/H impulse writing on the flywheel is either directly to the front & rear.. If you hear the snap & it�s at the correct time make sure the L/H side spark plug is sparking as the L/H impulse writing on the flywheel is to the rear & the L/H impulse mark on the flywheel is lined up with the trans case mark [at 3�oclock behind the flywheel & even in height with the center of the crankshaft]..
~If all ok per above so far & it still won�t start or pop, then try putting about 3 oz of oil in each cylinder & trying to start it..
~If still no pop or start it might not hurt to run a compression test on it & if low suspect sticking valves or stuck rings..
~If it still won�t start try pull starting it..
~If it won�t start by pulling it then you will need to pull the carb off & verify it isn�t plugged up or full of varnish or rust inside [common on a Deere tractor that sits in storage for long periods]..
~If you just can�t get it to start no matter what you might need to start at square one & verify you have correct cam timing & good compression..
~Basically you will have to work your way through all the systems & verify they are working correctly..
~Any questions just post back or E-Mail.
[email protected]
JDVan
02-01-2004 18:10:49
You have received some good suggestions but let me add a couple more. Are you getting compression? Take a plug out and check if you are truly getting compression but equally important are you getting suction? W/o either one, even pull starting may not solve the problem. No suction but compression, check intake manifold gasket or stuck valve. If it is purely a cylinder wall oiling issue, squirting some oil into the cylinder through the sparkplug hole might help get enough compression to get going after a few revolutions. Are you truly getting spark when the plug is in the cylinder under compression. Are you getting spark at the sparkplug gap with the plug grounded to the frame but out of the cylinder? Following a logical trail will get you there. The carburetor may be plugged and not allowing any gas to the cylinders either. If the plugs are getting wet that usually means you are getting gas into the cylinders.
Kris A
02-01-2004 17:16:13
Old might be right. If she has sat for a while the oil from the cylinder walls maybe gone and the compression is just not there to pull the fuel in. Try pull starting like he suggests. Maybe someone else will have a little more advice to help you out as well.
Kris A. NC
old
02-01-2004 16:50:13
Well I don't know much about an H but if you have spark and fuel to the carb you might try pulling it, if its sat for a long time some times they just don't want to start up. I had to do that to my 1935 B the first time and ever since it starts after about 7 turns of the flywheel
