39/40 B transmission
Jason Z in MO
08-06-2004 10:36:04
I have been tearing down my B SN 81291. Cleaning parts and priming them as I go. What I have together still are the rear axles and transmission. The engine components are all removed from the main case. What should I look for when getting into the transmission?
I know the right rear axle final drive gear (bolted to the axle shaft called the bull gear?) has been repaired. I can see where some of the gear teeth have been welded. Whoever did the work did a nice job but I would prefer to replace the gear. Any other advice when replacing this gear? Should I replace the gear this one meshes with?
I want to do it right the first time... I guess I am a little reluctant. I haven't done much work on transmissions.
This should be right up Clooney's drive shaft! :)
Sorry couldn't help myself because he sure does know the inside of those boxes!
