6600 combine engine swap
billyiron
08-06-2004 10:24:33
how hard would it be to put a 404 diesel from 6600 to a 4010 or 4020; thanks
WTW
08-06-2004 11:13:07
 Re: 6600 combine engine swap in reply to billyiron, 08-06-2004 10:24:33
billy, If the engine has the injection pump at the front of the block, driven off the front timing gears it is a later 404 engine as used in a 30 series tractors. If your tractor is a gas model it will need a different Air Cleaner, Air Piping, Flywheel, (original fly wheel can be made work with some machine work) Oil Pan (original oil pan will work but a few quart smaller in capacity) Oil Pump Pickup, Throttle Linkage and Front Pulley. If your tractor is a diesel model your flywheel and oil pan will work. The 30 series engine will require some work as the water pump is set much more forward and interferes with the radiator. I have used this engine in the 4010/4020 application and gotten it to fit without altering the sheet metal or lengthen the frame rails or moving the radiator as some people do. It did require the Front Pulley, Timing Cover and Water Pump to be machined / altered. The most economical route is get an early style 404 engine as it will bolt right in and be less than half the work. If you have more questions holler back. Dave W.
Bob
08-06-2004 10:38:47
Make sure the front of the combine block is drilled for the 4 bolts and two studs that hold the hyraulic pump adapter to the block. Not all the combine engines are.
