Gonna try here-Elecrolysis my first try
msb
08-06-2004 08:36:42
Didn't get much response at Restoration Tips.
And now a million questions pop into my mind.Always seem to have a flair for going too big to start with.Got an old 170 gallon plastic chemical (EX chemical)tank.Put 90 gallons of water and 3-18 oz.cans of lye in it.Put my Massey 44 grille in it for starters.See,I said big.(Hey, it will hold a complete fender if I can make this thing work.)Hook up a 10amp trickle charger to a rusty piece of expanded steel and turn her on.Bubbles??? What bubbles?? See a very few tiny ones.What should I see besides a tank that looks like it is filled with blood 24 hours later???I can wire brush most of the paint layers off under water hose.Some shiny metal but not much.Not enough current flow??Need to see more bubbles??? Would a 120 volt transformer/rheostat be better? Have to figure out which is negative side if it will.Would it be better/quicker to use the lye gravy on large pieces first?Should I clean the electrode first??? How long should the process take???What about shelf life of lye gravy???Can I keep it around a few weeks if I don't need it all at first???Thanks for helping me have the time of my life???Radiator, you are next!!!lol,bob
F-I-T
08-06-2004 09:48:43
 Re: Gonna try here-Elecrolysis my first try in reply to msb, 08-06-2004 08:36:42
Bob:
Let�s try your questions one at a time:
....Got an old 170 gallon plastic chemical (EX chemical)tank.Put 90 gallons of water and 3-18 oz.cans of lye in it.Put my Massey 44 grille in it for starters.See,I said big.(Hey, it will hold a complete fender if I can make this thing work.)Hook up a 10amp trickle charger to a rusty piece of expanded steel and turn her on.Bubbles??? What bubbles?? See a very few tiny ones.What should I see besides a tank that looks like it is filled with blood 24 hours later???
First, remember that you can use either Lye (NaOH) or Washing Soda (NaCO3) or both for electrolyte. Washing Soda is much cheaper, but the Lye will work on the paint even if the current flow is low or absent because of its strong base properties. Mix it at a rate of about one tablespoon per gallon, though I find that the rate is not all that critical. I sometimes use and old plastic lye bottle , cut some slits in it and fill it with washing soda and let it float in the tub. That way it leaches out extra ions if the bath needs them. Sort of like a swimming pool chlorine feeder.
Does your 10 amp charger have a meter on it? If not, you may never know when you have the connections correct/clean/stable. I adjust the strength to keep the charger humming and while not popping its breaker. Why not try it with a couple of small pieces in a five gallon bucket until you�re sure it�s working. It won�t look like its boiling, but it will bubble. Actually more like a constant fizz. You should see that at the point of where the connection is made. If not, you don�t have a clean connection.
Your electrode needs to be clean so that it can �see� the electrolyte. I like stainless steel sheet because it lasts a long time and sheds the red rust residue easily. When your wife is not looking, try using one of her stainless steel cookie sheets. :)
One thing to remember is that the electrode should at least have as mich surface area as the piece that you're trying to cook. I once had an e-mail from a guy who said the process wasn't working for him, and whn I asked about his set-up he told me he as cleaning a car fender and using a spoon for an electrode.
....I can wire brush most of the paint layers off under water hose.Some shiny metal but not much.Not enough current flow??Need to see more bubbles??? Would a 120 volt transformer/rheostat be better? Have to figure out which is negative side if it will.
I would STRONGLY advise against using a high voltage power supply. You�re just creating a likely electrocution hazard. Anything over 30 volts can kill you. AND, you should be using a ground fault interrupter breaker on this circuit as well. While the reaction goes faster with increased voltage, it also goes faster with higher temperatures, and higher concentrations of reactants. I actually have gone the other direction and now use a 5 volt supply that can yield 400 amps, and it works just fine. For your information only, you�d have to build a half-wave rectifier using some diodes in order to use house current directly. If you use an alternating current, you�d just be exchanging the rust from one electrode to another once every 1/60th of a second.
....Would it be better/quicker to use the lye gravy on large pieces first?
I use lye gravy on pieces that I cannot get in my tank. Lye gravy works on most every thing, but it fails on newer paints, or those with hardener. Electrolysis always lifts the dirt/rust/oil/grease/paint AND converts the red rust to black oxide.
....Should I clean the electrode first??? Yes.
....How long should the process take???
At 8 amps or so, and depending on the paint/layers/oil/grease/rust, I�d say overnight.
....What about shelf life of lye gravy???Can I keep it around a few weeks if I don't need it all at first???
You can keep it around pretty much indefinitely, but it will get stiff as the starch swells and uses up the water. I like to thin mine out with water if I have to store it. I can always add some starch to make it thicker when I�m ready to use it, but most times I use what I need at one sitting.
Frank-in-Tallahassee
70D // 855 // VAC // Farmall Cub
[email protected]
paul ostrander
08-07-2004 21:18:22
 Re: Gonna try here-Elecrolysis my first try in reply to F-I-T, 08-06-2004 09:48:43
I would like to know what kind of supply you have which will deliver 400 amps at 5 volts?
F-I-T
08-08-2004 00:49:44
 Re: Gonna try here-Elecrolysis my first try in reply to paul ostrander, 08-07-2004 21:18:22
third party image
It's a computer rack supply made by Lambda. The 5 volt side is used to power the TTL logic circuits on very large systems. EBay, $65.00, 240V and it has its own fan! At 5V, I cann reach in the bath anytime I want, but I don't think I've ever had it over 50 amps yet.
Frank
Thanks Frank
08-06-2004 20:44:34
Think you helped me a whole lot.The transformer/ rheostat I was planning to try can be set at a low voltage.I was concerned I wasn't getting enough amps to do the trick.Sounds like I should start by addressing the electrode issue first.Its a nice big piece of expanded metal so the first thing I need to do is clean it first,I guess.Sure have a lot of neighbors watching the process and I am in enough trouble with the wife as usual.Besides I LIKE her cookies!.lol,bob
