A trans trouble
Travis T
08-06-2004 08:13:08
iv got a 38 A that runs fine but when i make it work (plowing)in low gear the high low lever pops out of gear. i want to put it in a tractor pull but it wont stay in gear. what is wrong? iv put new trans fluid in and tried to tighten the shifter. help me please!
Clooney
08-06-2004 09:24:00
 Re: A trans trouble in reply to Travis T, 08-06-2004 08:13:08
Travis T, the usual cause of a 2-cylinder trans jumping out of high or low range is worn input shaft/sliding gear shaft bearings,, that would be followed by a worn detent notch for the shift rail.. You could also have a bent or worn shift fork.. There were also some cases of the shift rail lock bolt coming loose on some of those old A�s..
About the best approach is to pull the trans top cover & reach down in & give the input shaft & sliding gear shaft a pull & tug,, if there is much lateral or vertical movement in either shaft you probably need new end bearings.. If the shafts are relatively tight look for a loose end on the shifting fork, or real weak detent springs, or worn detent plungers.. Use a long screw driver & see how much effort it takes to snap the under/over drive gear out of engagement,, if it moves rather easily you probably can help it stay in gear by re-working the U/O detent to be somewhat stronger. Look for the sliding under/over drive gear to fully engage when the detent is holding..
Take a look in the trans & post back if any loose bearings or shift fork problems found..
You might want to start by pulling that small outer bearing cover [behind the clutch pulley] to see if the outer input shaft bearing is worn out or the 1st reduction cover hole is worn oblong as that can make it work out of gear..
[email protected]
Mike M
08-06-2004 09:09:48
Worn bearings in the trans.and or worn gear teeth from someone shifting from high to low on the move.
