2355 MFWD SOLENOID REPLACEMENT
DAVE M
08-06-2004 06:16:49
I need to replace the mfwd solenoid. I was on
JD parts and looked up the picture. I see I'm going to have to take the solenoid apart to
install it. Any help, tips etc will be of a great assistance to me. Also the new solenoid has a different location for the hot and ground wires to go to, it also has 3 spades for spade lugs, which 2 do I hook to? Thanks in advance
david val
08-07-2004 03:38:29
 Re: 2355 MFWD SOLENOID REPLACEMENT in reply to DAVE M, 08-06-2004 06:16:49
if you need to replace the solenoid only (and not the solenoid valve assembly) it should be simple, there is a snap ring on the valve body that holds the solenoid in place. you remove the snap ring and pull off the solenoid. sometimes the solenoid get stuck to the valve body with corrosion. in this case you may have to careully apply force to the solenoid (best start with rotating force). the solenoid may be ruined and in extreme cases the valve may also be ruined. in this type of solenoid (contrary to the newer 7000 series type solenoides) the polarity doesn't matter, the 'active' spades are the two facing each other.
david
