JD 24 T Baler
poorfarmer
02-01-2004 16:13:44
I have a chance to buy a JD 24T baler for $800 is that too high? It looks like its in pretty good shape. Knotters look good and the guy said he baled with it last year and it done a real good job. Thank you for any help.
old
02-01-2004 16:46:57
 Re: JD 24 T Baler in reply to poorfarmer, 02-01-2004 16:13:44
If it looks real good and every thing works like it should that might be a fair price. But I'd make sure that the knotters worked well and all the bearings etc are good, how are the pick up teeth??? Also if you buy it and if you plan to pull it home be sure to grease both the wheel bearings before you pull it any where. I didn't on a 14T I had and spent about 5 hours on the side of the road fixing a burned up bearing
