4320 Hydraulic for Vacuum Planter?
Gunner
08-05-2004 19:04:18
Will a 4320 have enough hydraulic flow to run a 7200 or 1750 planter with vacuum? I would like to get a vacuum planter but don't want to replace a tractor. Could I go to a pump from a FWA tractor to get enough?
Thanks
Gunner
cv
08-11-2004 08:03:07
 Re: 4320 Hydraulic for Vacuum Planter? in reply to Gunner, 08-05-2004 19:04:18
yes it should...we have a 4020 with 2 svc..and that works great on the 7200 8 row
Wayne
08-09-2004 06:45:26
What you need is called a ported filter cover. It is for the return oil off your orbit motor on your planter. What you do is hook one hose to the motor for pressure out of your SCV and the other hose goes to the ported filter cover for your return oil.
G-MAN
08-06-2004 07:42:01
If the system is in good shape, you should have enough flow to run that vacuum motor. Those motors don't take a lot of flow. You might run a little short when coming to the end rows, raising the planter and maybe a marker. How many boxes on the 4320? Make sure it's got the bypass line on it so when you snap the SCV off the motor can smoothly coast to a stop instead of stopping instantly.
Gunner
08-06-2004 15:45:30
 Re: 4320 Hydraulic for Vacuum Planter? in reply to G-MAN, 08-06-2004 07:42:01
Thanks for the info. I have 2 SCV's on the tractor but am lost on the bypass line part. Is it on the tractor or part of the planter setup. I think the planter manuals show a return into the trans case for the oil. Is that what you mean or is it something different?
Gunner
G-MAN
08-09-2004 10:47:11
 Re: 4320 Hydraulic for Vacuum Planter? in reply to Gunner, 08-06-2004 15:45:30
It's a line on the vacuum motor itself, tying the pressure and return sides together so that when you pull the SCV lever to turn off oil flow, it doesn't dead-head the oil in the return side and slam the motor to a stop, but instead allows it to continue turning and gradually wind down. Or you could plumb a power-beyond coupler into your hydraulic system and use it to operate the blower, along with a needle valve to govern the speed and vacuum.
