4020 PTO SLOWS DOWN WITH LOAD
JOHN BRAWNER
08-05-2004 19:01:07
HOW MUCH TROUBLE IS IT TO REBUILD THE PTO. ON A 66 MODEL 4020 WITH POWER SHIFT ,CAN THIS JOB BE DONE AT HOME OR THERE SPECIAL TOOLS INVOLVED ?
WTW
08-06-2004 07:11:10
 Re: 4020 PTO SLOWS DOWN WITH LOAD in reply to JOHN BRAWNER, 08-05-2004 19:01:07
John, Knowing your abilities, you can do it yourself. Make sure your problem is not the control lever arm lose on the control valve, located behind the light switch kick panel to the left down in the bottom left corner. This arm is attached to control shaft with a 1/4" nut, lock, and flat washer and is prone to work loose on shaft when dirt gets packed in under arm. Check this area first!! Arm will have flat sides of hole wore out turning on shaft. To service the PTO clutch the tractor will have to be split between engine and clutch housing. Throw out bearing and fork will have to be removed from clutch housing. Take the eight 3/8" bolts from clutch pack / transmission pump out and pull clutch pack from clutch housing. Put clutch shaft of clutch pack through a hole in a bench top or a barrel will work good to support clutch pack on end. Remove the six 5/16" bolts to disassemble clutch pack. The PTO clutch is the first clutch under the cover. Call me if you need some help. Pretty simple program. Dave W.
