430 S Hydraulic Problems
elliott
08-05-2004 07:46:21
I have a 430 S that has a hydraulic problem. The 3-point hitch has been dragging over the past few years but has always responded to adding fluid. About 2 weeks ago, it would not raise at all. Fluid was ok. I have removed the pump and replaced all the internal seals, bearings,and rings. That did not fix it. I am not sure what could be the problem. You can raise the arms by hand and they will not drift down under a load. I have not taken the rackshaft housing apart yet. Any help please?
Henry J
08-05-2004 15:04:43
 Re: 430 S Hydraulic Problems in reply to elliott, 08-05-2004 07:46:21
Elliott
I could not figure out what has gone on. Did you overhaul the pump, reinstall it, and then it has not worked since?
If that is the case the first thing I would look into is if the pump got primed. Crack the fitting open a tad where the high pressure line goes in the tom and see if you are getting a flow of oil. If not then the problem is from there forward or air is getting into the return line via a hole or bad seal.
Ray
08-05-2004 13:49:55
The problem is usually on the other end.The piston seal on the rockshaft housing is probably
old and dried up letting oil bypass.
