power block
Al R
08-04-2004 16:56:05
What does a power block consist of?
CMB
08-04-2004 20:14:07
 Re: power block in reply to Al R, 08-04-2004 16:56:05
They were an aftermarket block with oversize, (quite a bit oversize, in fact)pistons. Most, if not all were supplied by the old "Tractor Supply Co". They were made at least for "B"s & "50"s(5 1/2"), "A"s & "60"s(6"), & also for "G"s & "70"s(6 1/2"). As can be seen they added a lot of cu.in. to each model, earlier "B"s went from 4 1/2" to 5",while late "B"s & "50"s went from 4 11/16" to 5". The "A"s &"60"s all went from 5 1/2" to 6", while the "G"s went from 6 1/8"to 6 1/2", & "70"s were increased from 6" to, I think the same 6 1/2" bore as "G"s. I had a "G" with one, & it would pull 4-14s most anywhere in third gear.(4 1/2 mph if you were running rated 975 rpm). Mine was speeded up till it ran about 5mph in 3rd. I still have a "60" with one, & it would almost, but not quite, keep up with a stock "70".
Hank
08-04-2004 18:58:58
It was an after market block that had a bigger bore. They were numbered 1,2, and 3. Had a 6 inch bore.
