1020 anti-diesel solenoid
Steve n VA
08-04-2004 15:48:48
I have just had to replace this solenoid for the second time in 6 years. Not a great failure rate but at >$100 a pop I'm interested in alternatives. Has anyone simply removed the solenoid and plugged the opening? Does the tractor diesel? Does anyone know of a good replacement carb? Thanks in advance.
Bob
08-04-2004 16:35:19
 Re: 1020 anti-diesel solenoid in reply to Steve n VA, 08-04-2004 15:48:48
If it is the non-adjustable type, in a pinch, I have seen guys just simply snip off the needle valve sticking out of the solenoid, but be prepared for dieseling, or muffler backfire on a hot shutdown. It's worth a try, as the burned-out old solenoid ain't worth a heck of a lot!
msb
08-04-2004 16:25:14
Yes,they will diesel without the solenoid.Not sure about the 1020 but most of those solenoids served as a load speed adjustment as well.To do away with it would entail replacing it with an adjustable load speed jet from another carburetor. I have done that on other models but the results were less than satisfactory.
