Tye, The PTO on my 50 has always been a little noisy in the two years or so I've owned it. The noise is pretty much a whine which pulsates along with the engine firing. I recently pulled the PTO assy along with the rockshaft housing to re-seal everything, and found a worn bushing on the PTO shaft. I think replacing the bushing helped the noise a little, but not significantly. I think it's mostly gear noise. The bushing probably failed from poor lubrication as the PTO was full of water when I got it. The other poster makes a good point in regards to the clutch plates. My PTO clutch has always worked well with no apparent slippage so I'm guessing that it's okay on my machine. The parts manual will show you all the bushings and bearings that are part of the PTO system. The parts manual covers the "live" PTO like mine as well as the transmission driven PTO. I've never seen a 50 without live PTO but apparently there is such a thing. If you don't have a parts manual, drop me a reply to this post and I'll see what I can do to help. Best of luck, John 1953 Model 50
