3-14 plow with a 520 LP??
Tyler-MO
08-04-2004 14:32:59
Hello all....
I finally have finished my 520 LP. I will post pictures asap.
One question is will my 520 LP pull 3-14" pull type plow?? I have one available to me for a reasonable price. I would like to work it pretty hard to seat those piston rings. Thanks for any input
Tyler in Missouri
Merle Hoppenworth
08-05-2004 11:01:16
 Re: 3-14 plow with a 520 LP?? in reply to Tyler-MO, 08-04-2004 14:32:59
Tyler, in my humble opinion,I would try to get access to a dyno for several hours and put varios loads on it for before pulling 3-14. It would be a shame to score a piston after all the work and trouble finding pistons as I remember you had. 3-14 is a good load for a 520 and it can handle it in some soils, but give it some time for the rings to seat without maximim load. My $.02 worth.
Tyler in MO
08-06-2004 06:21:31
 Re: 3-14 plow with a 520 LP?? in reply to Merle Hoppenworth, 08-05-2004 11:01:16
Merle,
I have about 10 hours of run time on the engine now. I put it under heavy load for short periods of time after I completed it by pulling around a very large rock in the pasture. It smokes going downhill in road gear. In 4 hours run time in a recent tractor parade(excursion) it consumed 2.5 quarts of oil. I have been advised to cover up the screens infront of the radiator and allow the engine to really warm up (200 deg plus). I have access to a dyno for $25/hour...kinda pricey..but if it really must be done I'll do it. I was advised to put the 520 on a feed grinder/mixer and use it like a dyno...it's free and should do the job. Let me know what you think. Thanks
Tyler
Joe P.
08-05-2004 05:19:35
A 520 will not pull a 3-bottom as fast or deep as you normally would want. You can definitely give the tractor a workout with it. And pull types are harder on a tractor than mounted ones.
720Deere
08-04-2004 16:15:35
Tyler,
That's a pretty subjective question. A healthy 520 should pull that plow in 2nd or 3rd gear depending on ground conditions, percent of grade, etc. You will probably get opinions that say no, but I have seen it with my the 520 that my dad used to farm with. He pulled a 3-14" mounted plow for many years and our ground is hilly and sticky soil.
