Oil/Clutch-Clooney or John T
Larry T
08-04-2004 10:24:13
Just returned from a 160 mile 3 day tractor ride in northern Iowa with my 50 "A". Noticed two problems: Small splatters of oil that seemed to come from the clutch area. This was the first time this has happened. The other was when at full throttle the steering wheel vibrated. Is this wheel bearings or stearing gears? Other than this it was a great three days.
Clooney
08-04-2004 11:29:01
 Re: Oil/Clutch-Clooney or John T in reply to Larry T, 08-04-2004 10:24:13
Larry, you ask...
Quote: "Just returned from a 160 mile 3 day tractor ride in northern Iowa with my 50 "A". Noticed small splatters of oil that seemed to come from the clutch area"..... Answ, that is somewhat normal.. There really isn"t an oil seal but instead a kind of reverse type screw threads on the operating sleeve the channels MOST of the oil back into the 1st reduction cover area. Thin motor oil like 10W30, excess combustion blow-by, excess wear between the operating sleeve & pulley hub, excess clearance in the R/H main bearing, blockage in the oil return holes of the pulley or dust shield. or the R/H main bearing shim packs improperly installed can all contribute to an oil slinging problem.. They all do it [sling oil] a little some just more then others..
Quote: �The other was when at full throttle the steering wheel vibrated. Is this wheel bearings or steering gears?��.. Answ, if the vibration is road speed related [the faster you go the worse it gets it could be wheel bearings or loose steering gear lash, or way out of balance tires, or distorted tires, or bent rims.. If the vibration is engine speed related [the higher the engine RPM�s the worse the vibration] then it is either engine balance, excess engine RPM�s [what is your fast idle engine speed], the clutch driver installed a notch or two out of alignment, flywheel balance or position related, or some of all of the above..
Most of those old A�s do vibrate the steering wheel at certain engine RPM�s,, some worse than others.. Aluminum pistons make it worse & a loose rear steering shaft bushing adds to the vibration.. If it only does it at high engine RPM�s check & re-set your engine fast idle, make sure ALL the engine & frame bolts are tight [loose bolts can make it vibrate like crazy], check the alignment position of both the clutch driver & flywheel to crankshaft [both have marks like this >< that must line up.. If your horizontal steering shaft has a loose rear bushing replace that & if your horizontal steering shaft has any fore/aft end play remove some front cap shims to remove the end play..
I have a few old A�s & one vibrates like crazy at high RPM�s one is pretty smooth & one is about average so a lot depends on initial engine balance & the piston weight.
I had a �B� a while back that vibrated so bad it put my hands to sleep after using it a while so I used stick on wheel weights inside the flywheel rim to balance it out [took about 4 placements to find the correct location & mass for the weights].. The weights are still there, next time I pull the flywheel [if I ever do] I will remove the weights & drill the flywheel opposite the weights..
[email protected]
GPWT
08-06-2004 09:48:54
 Engine balance in reply to Clooney, 08-04-2004 11:29:01
As I recall the two cylinder engine rotating parts (crank, flywheel, drive disc) were dynamically balanced as a unit, also piston/conn rod assemblies were sorted by weight and "matched" pairs were installed on the engine.
Most of the two cylinder tractors have had at least some of these parts replaced, if this was done the balance would be affected.
