JD 317 engine replacement
Ernest Swauger
08-04-2004 09:12:37
Engine on JD 317 w/ original Kohler KT17QS broke a connecting rod (surprise!!). Other than Kohler series II, are there any other engine conversions which are relatively simple to accomplish--I seem to remember a 25HP conversion on the web somewhere, but cannot find it now. Thank you.
08-04-2004 12:04:05
 Re: JD 317 engine replacement in reply to Ernest Swauger, 08-04-2004 09:12:37
My brother just finished repowering a 60" Yazoo with a 24hp Honda. Sounds great & he says it works really well. I helped him a little on it & wasn't that big of a job. The original engine was a Kohler model K582S-guess what-broken rod!
Jason Z in MO
08-04-2004 11:28:06
Must be a common issue with the Kohler KT17QS. I replaced the engine on my father-in-law's 317 for a thrown rod. About a week or two later I replaced another 317 engine due to a broken rod. Both went through the block at the same place. I just mess around in my farm shop; I'm not a regular repair shop. These just happened my way by chance.
NOT complaining... Both engines and tractors have put in over 20+ years of solid use.
buickanddeere
08-04-2004 10:45:04
Link
Henry J
08-04-2004 10:13:27
Ernest
I vaguely remember that maybe Briggs also has a conversion/replacement. Take a look at a web scan for Northern Equipment or Northern Tool
Andy
08-04-2004 10:06:49
Check out the link below. It even has a kit for a 24 horse Honda! I might have to get a 317 with a blown engine...
Mike M
08-04-2004 09:48:13
John deere used to have a part number for a conversion that used an Onan engine. They may still offer these. You may also want to try to get hold of Roy Pagent engine sales I think in Indiana.
Bus Driver
08-04-2004 16:16:50
 Re: JD 317 engine replacement in reply to Mike M, 08-04-2004 09:48:13
Interesting topic. Mike, how does the price of a new Onan compare to a new Kohler? I assume that both are pricey.
Mike M
08-05-2004 05:04:08
 Re: JD 317 engine replacement in reply to Bus Driver, 08-04-2004 16:16:50
I have no idea what these cost,it sounds like there may be alot of choices out there.
Bob
08-04-2004 16:39:25
They're both higher than heck, and the series II Kohler is as good as the Onan, making the cost and labor of a changeover unnecessary, as the Kohler is a drop-in replacement.
However, some of the newer V-Twin OHV engines are a great way to go because they're more efficient OHV engines.
