Hey Mud Sock Bob 4010 PTO ?
Whitefield
08-04-2004 08:26:02
You are without a doubt the expert on these machines. I recently got the 4010 diesel running after over 1 year of pieces laying everywhere. I had it split and installed a case 1070 PTO stub shaft. In the process of doing all this I also put in a new PTO brake. However the brake doesn't work. I read the Service manual on adjusting the PTO lever. It seems that the 3/4" play that is supposed to be set to loosens everything up- like the PTO would not fully engage. Can you clear this up for me. The PTO brake would move when the machine was split. Thank you for you time- or anybody else's that can help me out.
msb
08-04-2004 16:41:20
 Re: Hey Mud Sock Bob 4010 PTO ? in reply to Whitefield, 08-04-2004 08:26:02
You are too kind.Not sure I can live up to your accessment of my skills.LOl.I am not clear on your post.A Case 1070 shaft?Threw me for a loop on that one.First of all, is the detent free to move when the lever is pulled all the way rearward.Sometimes they take a "set" and won't retract all the way back into the bore.With the lever in the "home "position you should feel the bearing pick up the resistance of the clutch fingers when the lever is moved 3/8" forward measured at the detend area. Not the tip of the lever.Adjust the turnbuckle so it picks up the bearing as stated.You did set the pto fingers with the proper gauge didn't you?With a pilot shaft in place and the other two operating levers wedged in place against the disk, you set the other operating lever height,correct?I always use a couple large screwdrivers as wedges,being careful to not wedge them too tightly.That can throw off your adjustment but not enough so the brake won't come on.
Stan - Florida
08-09-2004 20:12:37
 Your Handle (Mud Sock Bob) in reply to msb, 08-04-2004 16:41:20
Just curious about your handle. Would you happen to be from Central Indiana? There is a town there that used to be nicknamed "Mudsock".
Stan
Whitefield
08-05-2004 07:14:13
 Re: Hey Mud Sock Bob 4010 PTO ? in reply to msb, 08-04-2004 16:41:20
Some clarification. The case part is just a receiver & reverable stub shaft at the rear- so I no longer have the JD bolt on stub shaft. Only the rear 12" of the whole PTO shaft is not original. I didn't do anything with the PTO fingers or clutch- I had it split between the transmission and the clutch housing. It sounds like you are saying that I should feel resistence when pushing the lever forward 3/8" measured at the hole for the rod. I will adjust that. When the lever is in the "home" position it wqill not move rearward any- it is solid feeling. I'll have to do somemore checking & get back to you. Thank you.
