4255 pto seals
Greg S
08-03-2004 08:08:33
G-Man,
My 4255 continually leaks from the seal around the pto shaft. I don't use the pto but try to remember to run it occasionaly to keep it from drying out. How hard is it to change this seal and is there a "permanent" fix to this problem.
Jim B
08-04-2004 05:14:57
 Re: 4255 pto seals in reply to Greg S, 08-03-2004 08:08:33
Greg,G-Man is right on.I replaced my seal on my 4255 last year and knock on wood it's still dry.I couldn't believe the original seal only lasted 8000 hrs.My dealer sold me a part# R130561 that I could not see where it went so I left it out.I didn't drain trans.I just nosed it off VERY CAREFULLY in a ditch.As I custom bale hay my pto turns more than it's stopped.Jim B
G-MAN
08-03-2004 10:29:37
It could either be leaking from the o-ring that seals the stub shaft (the one you swap to go from 540 to 1000 and vice versa) into the guide, or between the guide and the lip-seal that seals it. Pull the stub shaft (you'll lose some oil) and inspect the o-ring. If it looks okay and the stub shaft seal surface is good, you'll have to go deeper. Unfortunatly on the small-frames, that entails draining the trans and pulling that entire quill assembly. On the large-frame tractors you can hook up a shop vac to the oil fill and change the seal without even draining the oil. Once you get the quill out, it's pretty self-explanatory - a ball-bearing to support the guide in the quill and a lip seal to seal it, with a couple of snap-rings holding the hole works together. I'd recommend replacing the guide if it's grooved or worn at all. It's a little pricey at $90, but usually cheap insurance against another potential leak. Replacing it, the seal, the o-ring in the guide and of course the quill gasket should get you back into leak-free condition.
Greg S
08-04-2004 07:11:59
 Re: 4255 pto seals in reply to G-MAN, 08-03-2004 10:29:37
Thanks for the info. I had the seal replaced about three years ago when I had it at the JD shop in Kimball but didn't seem to help, tractor only has 4100 hrs.
