Fix leaky fuel shutoff valve?
Brandon
08-03-2004 01:42:34
I was wondering if it is possible to fix a leaky needle valve fuel shutoff. It is certainly leaking externally, and maybe? letting fuel by when shut off. This is for the diesel tank on my 80.
Thanks,
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Clooney
08-03-2004 04:29:20
 Re: Fix leaky fuel shutoff valve? in reply to Brandon, 08-03-2004 01:42:34
Brandon, you can try to repair yours..
Try pressing the pin out then chucking the needle valve in a lathe or drill press & using some fine sand paper to dress the needle end, then polish up with some fine Scotch Pad.. Maybe twist a small wadded up piece of Scotch Pad down into the seat to clean that up..
Not sure if Deere still sells the packing but if not try a small "O" ring or wrapping some valve packing string around the valve top under the packing nut..
Most of those old needle & seats will clean up & function good if you spend some time on them.
[email protected]
David Sloan
09-27-2005 07:55:06
 Re: Fix leaky fuel shutoff valve? in reply to Clooney, 08-03-2004 04:29:20
I replaced the fuel filter bowl on my 1947 John Deere Model M because it was dripping gasoline and ruining the paint.
I had to disassemble the fuel petcock from the new bowl in order to install it and sealed all the threads with a silicone sealant compound. But in spite of that, the NEW bowl leaks even worse than the old one. Gas appears to be leaking from the petcock threads and maybe other places too.
What is the proper way to fix this problem?
Thanks
David
[email protected]
