Help ID this 40S.
Brian
08-02-2004 23:31:33
Serial # 65918
It belongs to my brother-in-law. He hasn't cranked it in 3+ years. I brought it over to my house tonight..... put the disassembled carb back together..... cleaned out the glass sediment bowl..... and fired her up..... SWEET SOUND.
It has the wide front end, 4sp, "touch-o-matic" hydraulic control (what is that?)
What year is it? I am guessing a '54..... b/c serial numbers started with 60001 in '53.... and ended with 77906 in '56.
I am planning on using it with an old 60" finishing mower to cut my 2.8 acre yard. You think it will do the trick?
DiggerLarry
08-03-2004 10:29:28
 Re: Help ID this 40S. in reply to Brian, 08-02-2004 23:31:33
According to my material, 65918 was made July 53 the last group of the 53 model year. They were only made until Oct. 55. The Touch-O-Matic was the marketing name applied to the 3-point hydraulics system on the Deeres of that period. I have 40s and yes, they sure have a sweet sound. It should serve you well as a mower.
thane
08-03-2004 09:14:37
I can"t help ID the tractor, but I use my 40W with a 60" finish mower on my yard (about 2 acres), and it works great. I mow in 2nd gear, and I just make sure I don"t hit too many trees!
Claude Butt
08-03-2004 19:20:57
 Re: Help ID this 40S. in reply to thane, 08-03-2004 09:14:37
I run a 72" Landpride finish mower on my JD 40 utility in second gear for roadside mowing of mostly grass. It makes a nice load in not over 10 to 12' tall grass. The governor open up a little and sounds great.
